BarnabyHooge
So I posted earlier this week about a electrical issue that ended up as a condenser issue. Put a new one on and it started right up idling with ease. Used it maybe an hour, and the issue started up again. Assuming I got a junk part from TSC, I went and got another one. This time, I'm getting no spark, BUT EVEN worse I start noticing a black oily liquid coming from the 2nd cylinder... Didn't see anything in the 1st cylinder and I'm not noticing any radiator issues so I assume it's not just a head gasket.
Question 1: Are there thing that cause the condenser to go bad?
Question 2: Can a guy with decent mechanical skills figure out a piston/valve seal issue and fix it solo, or is that too ambitious?
Not sure what to do. I've never rebuilt a motor before and I'm sure it's not worth it to have someone else do it. The tractor itself also needs a new gas tank valve and carb work, could use new front rubber. 3pt. has a few minor issues but is functional.
I use it for plowing so I need to get this figured out before winter hits here in Wisco.
My wife doesn't want to hear me complain about tractors so I'm coming here ramble and vent . Ug.
