4000/4600 parts interchange?
Ultradog MN
Location
Twin Cities
Could a guy put a 4000 lift cover on a
4600? Would everything work properly?
4600 hyd pump has about double the flow of
a 4000...
What about flow control valves? Would they
interchange?
As far as I know the lift tops will inner change, I'm looking at swapping a 3930 lift top onto my 4000, I like the look of the raised controls.
The flow control valves should operate under the same principle and fit in the same housings.
The 4600 hyd pump probably doesn't have the oil level check plug and would need the remote suction filter in order to use the dip stick on the left side of the axle housing.
I hesitated to answer this because I don't have manuals for the -600 series to compare the components.
Where is the plug located on a 4600?
The ones on my 4000's are in the side of the pump.
4600 uses the same pump as 4610-4630, I have one of those pumps but it doesn't have a check plug, it came on a 3930 with a dip stick.
