Sealant for threaded fuel fittings
I am getting ready to put my 2000 back together and I was curious what do yall use for sealant on threaded fuel fittings such as on the fuel pump. I have seen alot of different people use alot of different things, but what is actually correct? I don't like to use thread tape, but I have used lock tite thread sealant and also permatex anaerobic sealant with good success. So anyhow, I figured I would ask what's the best choice.
Down here in Springtucky I use a product called Rectorseal with Teflon. Works real swell for me
I will have to look for it at the hardware store. We only have 1 hardware store and 1 auto parts store, so some items are limited!
I only intend to use it on the tapered threads on the fittings of the fuel pump and carb, not the flared fitting side.
The BEST product to use for NPT fuel line fittings is E-SEAL -see picture -made by GASOILA. I've been using it for over 10 ten years now and it's great. They make several thread sealing products -see LINK below...
Tim "PloughNman* Daley(MI)
GASOILA
The trick is to start layering the tape about 2 threads back from the start thread/end of fitting so that the tape does not come into contact with the gas but seals the threads.
I will also 2nd the RectorSeal recommendation. I have some yellow PTFE designated for propane use that is also rated for fuels that I use depending on situation.
They had the rector seal brand at my local farm store. Thanks for the replays, I wanted to use something good since the fuel pump fittings are a pain to tighten/reseal if they leak.
