Fighting suburbia in NC
My 63 2000 S-O-S rolled what I suspect is a rod bearing this spring. She choked down while running a PTO log splitter and stalled out then made the gawdawfulest screech when I hit the starter to fire her back up. Brand new Odyssey battery would barely turn her over so I quit before I ventilated the block or snapped the crank and brought her home. Having not yet had the time to get her rolled into the shop has given me alot of time to think about what to do/not do. Since the S-O-S has been limping for years and the radiator finally rotted out and now the motor has to be gone into I am beginning to wonder if it all adds up to time to start parting her out. Her tin is almost perfect (minor dings no rust), tires are usable, rear rims have never had calcium in them, even the front bolster pivot is fairly tight. I have a line on some supposedly good SoS trans but now the motor is the wildcard. I miss my seat time and hydraulic lifting capabilities but is rebuilding this and adding a Jackson power steering setup worthwhile compared to (gasp!!!!) going with used but newer equipment? What is freshening up the motor going to set me back provided I did not nuke the crank? Or is there even a market for good tin off of a 55 year old tractor?
I suppose I will eventually drag her into the shop and make my wife a shop widow for an extended time. Now that I have told my tale of woe can anybody commiserate with my situation and how did it turn out? I like my oddball DOT yellow S-O-S but not sure I can afford it AND a divorce LOL.
