mwelch2583
New User
Split my ford 2600 tractor due to a leaking rear freeze plug and the clutch throwout fork being sticky and not allowing the clutch to engage properly. While I had it split decided it would be pretty stupid not to replace all the clutch components as well, but have a ? on how to get the throwout bearing off. Do you need to drive the rod through the bellhousing out once the pinch bolt is removed from the "carrier/fork" or do you just pull "carrier/fork" forward enough to be able to remove it.
Im sure the component that the bearing is pressed onto is not called a fork, first tractor ive split so sorry for the automotive terms.
Thanks for any input
