ptrafford24
New User
I have a for 601 selecto speed . . . With no high
speed gears. . . And idea why. . . Just changed all thr
fluids and blew out filter. . ...have tried adjusting
bands. . . Didn't seem to do much
Welcome to the forum. But that is too generic to affect an answer.
Did you take the top cover off the transmission, remove and blow out the filter? Or did you just blow out the intake screen that you likely had to remove to drain oil?
Did you have the proper service manual to follow the correct band adjustment procedure? Or did you just start turning wrenches?
What oil did you refill the transmission with?
Did the transmission work properly before you did any of this?
Where did you put this oil into the transmission at?
What gears are inoperative?
Get back with the above info. It may help us help you to understand what is wrong and what next steps may be.
