I think that there is something wrong with the governor on my tractor. The engine only runs smooth in certain spots as I move the throttle. It mostly wants to to rev up and down while running.
When it does this the governor lever is moving forward and back witch then moves the carb throttle. Does anyone know how to fix this? I have a 64 2000 4cyl 134 engine. I had just replaced the dist. guts,cap,wires,plugs,coil,battery also a new carb, reset valve lash, checked cyl. compression (100-110), had front cover off to replace seals and gaskets.
