Hitch would intermittently work and then not work.
It has the cam mounted pump, I pulled the prime plug and it has plenty of pressure when I crank the engine over.
Is there a pressure regulator located somewhere that I can check?
Also the lift control lever for the hitch has some spring-back if you move it all the way up. It has always done that. Is it normal?
Anyone happen to have a digital copy of the manual anywhere?
Thanks!
Thanks!
