mikewood869
Recently we got our 1966 Ford gas 3000 with 8 speed tranny and live pto running again and went to go Woods mowing with the tractor and realized that the tractor had no pto, so I moved the tractor into the driveway and thought I adjusted the clutch by pulling the clutch release arm all the way, then I turned the clevis in (towards the clutch petal) between two or four threads and then reattached everything and then found out that only the pto works and I have no forward or reverse in any gear. Did I make the clutch too tight because pushing down on the clutch now is a lot harder? On our tractor, the tractor is missing the screw and lock nut and at one point it looks like that the clutch release arm broke and someone re-wielded it. When we installed a new clutch we didn't think of adding the screw or replacing the the clutch release arm. The clutch also has less that three hundred hours on the clutch (the clutch was installed near the beginning of Nov 2015.
