Ford Tractors Discussion Forum |
801 no spark
Author |
[Modern View] |
sfcrusscanter
09-19-2018 19:19:14
I was raking hay when the tractor quit. I knew the key switch was going out, it kept shutting down and wiggling the key would bring the ignition back alive. I started making trips to the local farm supply store for parts. I wired in a new switch, it cranks but doesn't fire up. I've replaced the coil, points, condenser, button and distributor cap. Next, using a light tester and then multimeter, I've verified 12.5 volts going through the coil and hot side of the points. Still no spark jumping through the points. I've pulled the new points and verified continuity going through the points when they are closed. I even tested the old points, that were about a year old for continuity. Both show good. I even went back to my farm and pulled the new points and condenser out of my 641 tractor (after I cranked it and verified it was sparking good). Even after installing them, still no spark on the 801. I had the owner of the field that I was "helping" him with go over what I did. You figure a Ford dealer mechanic for over 20 would catch what I'm doing wrong. Still no luck. I even got help for the local garage mechanic (50 year plus...). Nada... I was able to borrow a friend's JD4020 to finish raking and baling that field, and will use it to fining my five acres tomorrow. Now that I've had time to slow down and put my thoughts in order I figure that someone out here can point me in the right direction. The 801 has the 12 volt alternator conversation. I've had it for about four years so far without and major problems. Any ideas? Russ, in Kansas...
sfcrusscanter
09-23-2018 10:55:25
Re: 801 no spark in reply to sfcrusscanter, 09-19-2018 19:19:14
Got it running. Found two problems. The first was an intermittent grounding of The wire going into the distributor. The second was harder, the battery. Even though it cranked the engine at a normal speed and still showed 12.3 volts, it failed the test when I took it back to Auto Zone. I still am not seeing any spark jumping on the points, but since it's just to break the circuit I put it all together and it fired up. Thanks for all the help and ideas. Getting the battery out and in is the hardest task since I have a loader on the tractor.
da.bees
09-21-2018 10:36:54
Any time you have problems with point ignition,be informed new parts are not reliable. To free up your hands and better visability, I highly recommend "oem in line ignition spark tester #25227"from AutoZone. Use it instead of holding wires and watching for spark. Best $10 you will spend.
showcrop
09-20-2018 10:07:28
You will have better luck testing for voltage than for continuity. Don't accuse any electrical part of being no good unless you can verify that it is getting current but not doing what it should.
Larry NCKS
09-20-2018 01:50:59
Your problem is where the small wire enters your distributor body. Either the insulator is gone or the little copper strip inside is broken.
riveroadrat
09-19-2018 19:44:03
Someone here said dont throw parts at it till you find the problem. You can check for fire from the battery to the coil with a test light. If you got fire to the coil, you can use a plastic stick or something (you can use a screwdriver, even your fingers, but be careful what you touch, sparks fly wherever you ground the screwdriver) to just push the points open. Hold the coil wire to ground and manually open the points, you should have a fat blue spark jumping from the coil wire to ground. Someone said you can use something like a matchbook cover to slide between the gap to clean them. You should check your centrifugal advance and side to side play of the distributor shaft. I think a lot of people forget to oil them regularly.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin
... [Read Article]
Latest Ad:
Looking for a John Deere 50, 520 or 530 in good shape and preferably with power steering and three point. May be interested in a 620 or 630. Thank you.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
