hydraulic line scematic
good day, i have a 1965 ford industrial 3500 loader b/h, over the years things have been changed, the b/h is a 713 form aprox. 1962 it has been leaking under the seat, took hoe off tractor found leaks, questions is ,there are two valves. under there, believe one is flow control not sure of other, any help as to what line goes to what fitting is greatly appreciated, thanks ron
(quoted from post at 06:18:01 09/13/18) good day, i have a 1965 ford industrial 3500 loader b/h, over the years things have been changed, the b/h is a 713 form aprox. 1962 it has been leaking under the seat, took hoe off tractor found leaks, questions is ,there are two valves. under there, believe one is flow control not sure of other, any help as to what line goes to what fitting is greatly appreciated, thanks ron
If you still need pictures or info, I may be able to get you some. I have a 3400 with I believe a 713 backhoe. I cant guarantee everything is right because I bought it as a project and lots of the tractor was disassembled. But the hydraulic lines on the backhoe are untouched as far as I know. In return, would you be able to snap a few pictures to show where your b/h quick disconnects are mounted on the tractor?
(quoted from post at 12:00:42 09/17/18)
Ok, that would be great, I will post pics as soon as I get the b/h attachment back on the tractor
(quoted from post at 14:55:20 09/17/18)
I got busy last night, I'll try to snap some pics tonight. Sorry for the delay, things have been hectic lately
(quoted from post at 08:56:46 09/18/18)
both lines come from the front under the brake side running board then up over the rear axle under the rear seat[/img]
I hate to be like this, but I may not be able to get them after all. Since I don't have my hydraulics completely done, I have everything on the b/h chained and strapped to the tractor. I cannot get the seat/floor taken off with the chains in the way and I don't have a way to take the b/h off of the tractor either. I'm going to be going in for surgery in a few days and will have a weight limit for a month, so it may be a while before I can get to it. So sorry to have to tell you that... If you still need them in a month or so, I may be able to help out
(quoted from post at 19:40:19 09/19/18)
Ok thank you, I found a PDF of the service/repair manual and it has tons of info
