Company Logo Shop Now
Ford 950 Overheats Update
John P.
09-16-2018 08:57:57
So I tore it all down, and put it back together with a new radiator and water pump from Dennis Carpenter and a new thermostat and gasket from CNH. Started it up and still hotter than hell sitting there at a fast idle. Looked at everything harder and finally realized it was running lean as can be. After much poking, I found that the fuel line at the top section where it is made of rubber had decomposed inside at the bend and was blocking fuel flow except for a trickle. Just enough fuel was flowing to keep it running. So it looks like I need to makeup a new fuel line to get things going again. third party image
John P.
09-19-2018 08:42:29
 Re: Ford 950 Overheats Update in reply to John P., 09-16-2018 08:57:57
Well that was the thing, it was slower than the float's valve, so it seemed to be somewhat okay at idle, but could not keep up at higher RPMs.
showcrop
09-19-2018 04:43:46
Well John, I hope that you have found and solved the problem but it is hard to believe that a fuel line could be restricted to just the right opening that it could take the place of the float valve.
John P.
09-19-2018 03:48:55
The muffler was hot as can be to the point where the fuel tank got so hot, I was seeing vapors pouring out the vent!
I just bought one of those thermometers from the local Harbor Freight for about $25.
John P.
09-17-2018 09:35:25
After swapping out the fuel line for one without the trickle flow, everything was fine again. TEMP gauge is working great!
riveroadrat
09-18-2018 18:02:53
 Re: Ford 950 Overheats Update in reply to John P., 09-17-2018 09:35:25
I guess it was running like a blow torch. Now you can unload that noisy fan. I keep mine in case I have a hot runner sometime. A heat sensor gun is the thing to keep in your toolbox, you can check a lot of things that might make heat.
JMOR
09-17-2018 08:26:12
Quoting Removed, click Modern View to seeCan't speak experience on lean, but sure thing on late ignition timing!
Dean
09-17-2018 08:32:19
 Re: Ford 950 Overheats Update in reply to JMOR, 09-17-2018 08:26:12
Bingo, Jmor. That will do it.
So will a non functional centrifugal advance.
That said, experience has taught me that it's usually the gage or worn pump impeller.
Dean
Dean
09-17-2018 06:53:12
I cannot believe that the fuel line is causing it to overheat.
Have you VERIFIED that the temperature gage is accurate?
Dean
John P.
09-17-2018 03:18:27
That's what I'm going to try. Stopped by NAPA yesterday afternoon and picked up a 20" length of 1/4" brake line.
showcrop
09-17-2018 03:17:41
I made new fuel lines for two of mine with steel brake line, with a five inch section of rubber fuel line to allow flex.
Grandpa love
09-16-2018 19:51:29
I have a 960 and I made a new fuel line out of steel brake line. No rubber parts in it now. Crazy how hot a tractor will run if it's lean,or if timing is off.
John P.
09-16-2018 14:28:54
Yes it is quite noisy! This was already on it back when I first got it.
riveroadrat
09-16-2018 14:13:05
Ill bet that 6 blade fan is noisy, I used to have one, you might be able to go back to a 3 blade now.
Today's Featured Article - Recollections of a John Deere GP - by Charlie Cook. I grew up on my dad's 280 acre general farm in Western Michigan. Dad's only tractor when I was very young was the old GP. My first recollection of this tractor was when dad allowed my brother and myself to ride on the tractor with him driving. One of us would sit on the left fender (away from the clutch) and other would sit on the gas tank and hold onto the crankcase breather pipe. ... [Read Article]
Latest Ad: Wanted front suit case weights and rear wheel weights for a 1456 international. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
