stahlhouse2
If i start tractor put it in gear and look in oil fill for the diff i can see the ring and pinion going around. I shut the tractor off and
jack up the left side and spin the wheel i can see the ring and pinion going around. I jack up the right side and spin the wheel nothing is
turning in there. Is it a broken right axle? Could something be broke in the diff? How bad is it to change an axle? Where can i find one?
Would a used one with the bearing and retainer already on it be ok?
