Company Logo Shop Now
Order Ford 960 Parts Online
Ford 960 clutch pedal
Grandpa love
09-07-2018 16:03:12
third party image
When we used the finish mower the clutch pedal is way high. In the owners manual it says 9 3/8 is where it should be. Ours is almost straight up. Does the pedal height adjustment affect anything else? Or just pedal height? I hate to go move it and find out clutch ain't happy! Thanks!!
riveroadrat
09-09-2018 06:41:17
 Re: Ford 960 clutch pedal in reply to Grandpa love, 09-07-2018 16:03:12
You need to take all the slop out of your clutch pedal assembly also. New pedal bushing, maybe new tranny pin, maybe drill and bush the pedal where the pin connects, new pin, drill and bush the arm holes on both ends. You might find some nylon bushings for them.
Grandpa love
09-09-2018 10:02:49
 Re: Ford 960 clutch pedal in reply to riveroadrat, 09-09-2018 06:41:17
Sounds like I should leave it alone as long as it's working!!
mhb@ufe
09-07-2018 17:01:40
being able to set the pedal height at the correct measurement and still have the 2 stage clutch work properly is dependent on the pressure plate being properly adjusted. As the transmission clutch wears it changes the gap on the pressure plate that controls when the 2nd stage disengages. Because that adjustment requires splitting the tractor the clutch pedal adjustment gets changed to compensate.
Mark
Grandpa love
09-07-2018 17:06:45
 Re: Ford 960 clutch pedal in reply to mhb@ufe, 09-07-2018 17:01:40
So it's better to leave well enough alone?! If it works..........
mhb@ufe
09-07-2018 17:17:12
 Re: Ford 960 clutch pedal in reply to Grandpa love, 09-07-2018 17:06:45
You could try lowering the pedal and readjust your free play and see it works properly. Worst case you would have to put it back where it is now.
Mark
Larry NCKS
09-07-2018 16:23:59
I think 9 3/8 would be correct for a *50 tractor. If one sets the *60 pedal too low the PTO clutch is not going to be releasable.
riveroadrat
09-07-2018 18:33:43
 Re: Ford 960 clutch pedal in reply to Larry NCKS, 09-07-2018 16:23:59
Its probably wear on the discs and pressure plates. I have one thats almost straight up. Its a good leg exercise though.
Vito
09-08-2018 15:51:33
 Re: Ford 960 clutch pedal in reply to riveroadrat, 09-07-2018 18:33:43
Mine is like that also. I wouldn’t touch itt very expensive to replace if something goes wrong.
Vito
Grandpa love
09-09-2018 10:00:33
 Re: Ford 960 clutch pedal in reply to Vito, 09-08-2018 15:51:33
Yep. I agree. Will be leaving mine alone.
Latest Ad: Looking for two coulters and mounting brackets for a JI Case centennial plow [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
