Company Logo Shop Now
Order Ford 3000 Parts Online
Ford 3000 ID
dereks57
08-23-2018 10:57:03
I am trying to make heads or tails of this tractor ID. the numbers I have are
5F296
G0125
A111-084
Any idea from that what year it is? I am needing to replace the two stage clutch and would like to know what year it is. It has a European front grill on it.
Thank you for your held
Sean in PA
08-28-2018 05:37:29
 Re: Ford 3000 ID in reply to dereks57, 08-23-2018 10:57:03
A111084 is a very early Antwerp serial number, so the build date should be June 29, 1965.
Destroked 450
08-23-2018 20:42:10
5F296 looks like a production date but the 6 isn't right, look at it real close and see if it's a C instead
5 is the year, ether 65 or 75, does it have a vented hood or smooth hood
F should stand for June
29 is the date
If that 6 is a C it means afternoon shift
The A in the serial number means it was built in Antwerp, Belgium
IanC
08-23-2018 13:55:02
third party image
If you are trying to order a clutch before you split it you are wasting your time. When I was at the dealer we could call down to engineering with the serial number and they could tell us just about anything, but NOT what clutch was in it. Yes you can get lucky, but unless you are picking it up locally where you would have no shipping involved you need to split it and see what you have. I made up a cheat sheet for myself that will help you get the correct one the first time. Your date code appears to be June '65, but all model numbers starting with "G" are large row crop tractors so you need to clean up the stamping better and recheck it.
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: Needing good 70 series fenders. No rust or dents preferred. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
