Ford Tractors Discussion Forum |
gold demonstrators
Author |
[Modern View] |
Dylan berhorst
08-17-2018 18:14:47
What numbers were the gold demonstrators made in?
Tony Jacobs
08-20-2018 07:41:42
Re: gold demonstrators in reply to Dylan berhorst, 08-17-2018 18:14:47
Hello Dylan, The serial has to be between 60692 and 71484 if it is not it is not Gold. Thanks Tony
Tim PloughNman Daley
08-19-2018 05:17:46
Some sources cite January 16, 1959 as when the first Gold Demonstrator was produced, an 871 Model. the serial number range also has been listed as between 66000 and 72000 however some other sources cite that may have been as early as s/n 58000. The purpose of the Gold was to supply every Ford Tractor dealer with one to display and offer as a, well, a demonstration model for customers to see and try the new Select-O-Speed transmission. Since there were approximately between 3000 and 4000 tractor dealers, that s/n range given can be off a bit either way depending on how you do the math. If you use 58000 as the low end and add 4000, you get the to 62000 as the high end. If you use the stated upper limit of 72000 and subtract 4000 you get 68000. So, based on this, not ALL those s/n's were Golds then. They'd have to pull at random a few and have them painted gold. If you are trying to determine if you have one, best to check spots like under the hood, under the dash, and air cleaner for signs of gold paint. Tim *PloughNman* Daley(MI)
RickB
08-19-2018 06:19:27
Re: gold demonstrators in reply to Tim PloughNman Daley, 08-19-2018 05:17:46
By definition the serial number range is not inclusive. The range includes many models / variants that were never offered as Gold Demos. All tractors coming down the line were serialed consecutively regardless of model.
showcrop
08-18-2018 04:56:28
Dylan, if you are asking how many were made, there is no record of that, but the general consensus is that Ford pressured every dealer to take at least one, and there were many more dealers back then before consolidation and major highways. They are not rare enough to generally be worth much of a premium.
Larry NCKS
08-17-2018 19:17:57
871, 881, 971, 981 as far as I know
fordfarmer
08-17-2018 20:49:27
Re: gold demonstrators in reply to Larry NCKS, 08-17-2018 19:17:57
I could easily be wrong, but I thought any SOS-equipped model could have been a Gold Demo, from the 671 to the 1881.
ford9000puller
08-17-2018 21:02:45
Re: gold demonstrators in reply to fordfarmer, 08-17-2018 20:49:27
I have seen a few that were 671 or 681. Have seen one 1871 that belonged to Dwight Emstrom a big Ford collector from Illinois. Most are 871, 881, 971, 981 like Larry said. I would assume there were some 771s but I have never seen one. I have a 981 that is restored and an 881 that I bought as a parts tractor but it has gold all over under the blue and gray paint. It is on the to do list.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin
... [Read Article]
Latest Ad:
Looking for a John Deere 50, 520 or 530 in good shape and preferably with power steering and three point. May be interested in a 620 or 630. Thank you.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
