Good morning.
I have a 3910 that was formerly attached to a Brouwer 1570
sod harvester. We are no longer in the sod business, so I
removed the harvester from the tractor, with intentions of
using the 3910 for a spray rig. Low and behold, there is no pto
shaft on the tractor, which I should have guessed as there is
no pto shifter either.
There is a plate bolted on, covering where the pto shaft
should be.
Is it going to be possible to add a pto to my tractor? Or do I
need to find a new rear end for it that already has a pto?
should be.
