Ford Tractors Discussion Forum |
2810 cav injector pump
Author |
[Modern View] |
jwa
06-30-2018 15:28:10
Can the cav pump on my 2810 be turned up to gain some power? If so can someone give me some direction. Not wanting to pull or anything, would just like to have a little more power when bush hogging in thick stuff. I really like this tractor, but seems under powered.
RodInNS
07-02-2018 06:39:36
Re: 2810 cav injector pump in reply to jwa, 06-30-2018 15:28:10
The suggestion to turn it up 10% if and when it goes to a pump shop is the safest option. Doing that without a test stand or a dyno is not a good idea. The reality is that on the 158 engine, even with a 10% boost in delivery.. it's only going to give you another 3-4 hp anyway which will hardly be appreciable. Rod
thepumpguysc
07-01-2018 05:44:13
The simple answer is YES.. But its harder to do on the tractor, than Chinese arithmetic. & you stand a chance of washing down a cylinder. There are videos on it, but I wouldn't trust'm for the full info.. I would just take care of what ya got.. Change the fuel filters, clean the screen in the tank outlet, get the injectors overhauled w/ new tips.. AND WHEN the throttle starts to leak & you take it off to be repaired, tell'm to turn it up 10%..
jwa
07-01-2018 07:16:07
Re: 2810 cav injector pump in reply to thepumpguysc, 07-01-2018 05:44:13
Thanks, sounds like a plan. I can live with it as is but would be nice to have little more umph..
Sean in PA
06-30-2018 17:03:19
The 2810 only has the 158 ci engine, which was the smallest/weakest of any engine that they used with that heavier double reduction rear axle, so I am not surprised that you feel it is under powered. I don't know if you can turn up the pump any on it, but I am sure that others on here would be able to help you with that, but I doubt that you'll get much more than 4 or 5 more hp out of it if you do.
jwa
06-30-2018 17:13:04
Re: 2810 cav injector pump in reply to Sean in PA, 06-30-2018 17:03:19
Thanks Sean, yep don't know what ford was thinking when they grossly under powered these tractors. I really like everything about the tractor except the lack of power.
RickB
06-30-2018 17:27:20
Re: 2810 cav injector pump in reply to jwa, 06-30-2018 17:13:04
That’s why they made the 4610SU.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
Latest Ad:
need 3 point arms (with the ball) especially need the
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
