Company Logo Shop Now
select o speed oil pressure warning switch
texfordfan
06-28-2018 13:30:11
I'm looking for a replacement switch. The part # is 313942. It isn't available through Ford/NH or at any of my parts dealers here. Anyone have a spare or know where I can locate one?
Notoes
07-01-2018 00:37:54
 Re: select o speed oil pressure warning switch in reply to texfordfan, 06-28-2018 13:30:11
Glad to see you are making headway on this tractor. Can I borrow it to do some brush hog work around the pond?
LOL Keep me posted about the lights. :lol:
Larry NCKS
06-30-2018 15:34:18
Yeah! Thanks for letting us know.
texfordfan
06-29-2018 19:47:02
With all y'all's help and the local 'college of tractor knowledge' coffee group, I think I've found a substitute. I'm going to open her up tomorrow and begin by testing the old switch directly. If it fails as I think it will, then I'll try my substitute. If it works, I'll post the part # so that anyone else with the same issue can benefit. BTW, it's a currently available part from a parts house.
texfordfan
06-30-2018 11:52:26
 Re: select o speed oil pressure warning switch in reply to texfordfan, 06-29-2018 19:47:02
All right. So opened it up from the top. Good thing because there was no way I'd have had the leverage to get the old switch off, it was pretty tight. Disconnected the old switch from the wire, tested the wire, it was good. Next, tested the old switch. Bad. Hooked up the new switch and tested it, good. Installed and tested, good. Hooked it to the warning light, turned the ignition switch on and the light came on. So the problem was the old switch. Taking a break right now and then I'm going to close up the hydraulics and fire it up and see if the light comes on initially and then goes out. I expect it will. BTW, the switch I used is a NAPA #OP6619, it was a little long but all I had to do is bend the spade flat for clearance. I think I'm going to write that number in my shop manual if the final test comes out good.
texfordfan
06-30-2018 13:07:49
 Re: select o speed oil pressure warning switch in reply to texfordfan, 06-30-2018 11:52:26
All closed up and it worked like a charm. Now on to finding what the former owner did with the wires for the front and rear lights.
Notoes
06-29-2018 11:36:17
Texfordfan checked it out with his ohm meter twice and it was open both times. He even checked to see if there was any difference in the resistance when he ran the engine. The only connection he did not check was where the wire connected to the pressure switch behind the cover. Hopefully he will get time to open it up and check the switch without and wiring involved.
Thank you for the information on getting a switch. Hopefully that is all that is wrong with this light malfunction. He is fixing all his wiring issues properly before he moves forward.
Bern
06-29-2018 06:48:34
I just got a similar switch for a 5000 from a company called Nason, a model # SM-2C-20F.
The main difference would be the 2 PSI vs 20 PSI switch point. You can specify whatever pressure you want.
Larry NCKS
06-29-2018 04:04:36
I might add, check the one you've got for continuity to ground before determining that it's the culprit.
texfordfan
06-29-2018 08:33:36
 Re: select o speed oil pressure warning switch in reply to Larry NCKS, 06-29-2018 04:04:36
Good idea
Larry NCKS
06-29-2018 04:02:34
1/8" pipe plug, normally closed, opens @ 2 psi single spade switch. That oughta get NAPA what they need. Carquest, maybe.
Notoes
06-28-2018 14:56:35
Quoting Removed, click Modern View to see :P You have any idea what size the threads are on that switch?
Larry NCKS
06-28-2018 14:06:49
Ah hem. Did you not see my response to that on your other thread?
texfordfan
06-28-2018 15:31:40
 Re: select o speed oil pressure warning switch in reply to Larry NCKS, 06-28-2018 14:06:49
I don't have an O'Reily's here, only Napa and CarQuest. I'll probably have to take the old one out to get the measurement of the male thread.
Today's Featured Article - It's Alright Where It Is! - by Anthony West. I have a tale of a different kind to tell. Whilst rooting in the hedge bottoms this week I had cause to visit Chapel lane Farm, the home of an eccentric gentleman by the name of Austin Kendall. I had heard rumours that an old Case Model C was languishing away in the back of one of the outbuildings there. So off I went in search of what would turn out to be a very rare and unusual tractor. Mr Kendall is an excitable chap to say the least. He is amongst the last of a dying breed of farmer who ... [Read Article]
Latest Ad: Fiat 800E/ AgriPower 8000 Tractor for parts. Engine burned, but didnt get the injection pump or hydraulic pump. Back end of the tractor still ok, sheet metal is still there. Good for parts. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
