Company Logo Shop Now
Order Ford 2000 Parts Online
Ford 2000
OregonAaron
06-23-2018 01:02:37
Hello, I have a 75 ford 2000 and someone before me converted the fuel system to gravity feed. I know this is not right so I purchased a fuel pump and installed it. Now the tractor runs very badly and the carb pukes fuel out of the bottom. So I put it back to gravity feed (for now) and pulled the carb off to have a look at it. I did not open it because I do not have new gaskets, however I noticed the fuel inlet was jb welded in and there is a large crack in the casting that was jb welded as well. So I figure I should bite the bullet and order a zenith carb for it. My question is, will the zenith carb work well with gravity feed or does it prefer the 4 psi of the fuel pump?
Mike(NEOhio)
06-23-2018 11:11:29
 Re: Ford 2000 in reply to OregonAaron, 06-23-2018 01:02:37
I have a 72 2000 that my FIL got in exchange for hay he didn't get paid for. It hadn't run in three years. He bypassed the fuel pump and it's been gravity feed eversince. Only time I had trouble was when a small piece of dead leaf plugged the inlet to the bowl. And that was only an intermittent problem.
Ultradog MN
06-23-2018 04:52:43
I have a 3 cyl 4000 that was running on gravity when I got it. It would do some puttering around - PO used it to feed a large round bale a couple of times a week that way. When I got it it hadn't run for a couple of years and the Holley carb was all gummed up inside so I replaced it with a Zenith - still on gravity.
It ran good but did not have the power to effectively run a 6' rotary mower.
I had a small electric fuel pump and put that on it then it made good power.
However, my engine is a 192 ci and yours is a 158 ci and they use identical fuel system to the carb. So, you might do fine with gravity on yours. I would at least try it and see. If you do a search in the archives here you will find many posts about the Holley - often spelled Holly - and read what others have said about them. Some guys can get them to run right after a rebuild others, like myself, never could make them run right.
I just toss the things and buy a Zenith.
Zenith is very expensive but makes a 3 cyl tractor run Good.
Your call on that. If you do buy a Zenith maybe then try it gravity and see. Mine had most of the original fuel lines torn out is why I put the electric pump on. I have since collected original lines and some day will put everything back to original. For now with as little as I use that tractor it hasn't been a high priority.
OregonAaron
06-24-2018 05:29:09
 Re: Ford 2000 in reply to Ultradog MN, 06-23-2018 04:52:43
Thanks for your responses, I am going to purchase the zenith carb and run the fuel pump. I did not know if the zenith carb would run just fine without the fuel pump.
Today's Featured Article - It's Alright Where It Is! - by Anthony West. I have a tale of a different kind to tell. Whilst rooting in the hedge bottoms this week I had cause to visit Chapel lane Farm, the home of an eccentric gentleman by the name of Austin Kendall. I had heard rumours that an old Case Model C was languishing away in the back of one of the outbuildings there. So off I went in search of what would turn out to be a very rare and unusual tractor. Mr Kendall is an excitable chap to say the least. He is amongst the last of a dying breed of farmer who ... [Read Article]
Latest Ad: Fiat 800E/ AgriPower 8000 Tractor for parts. Engine burned, but didnt get the injection pump or hydraulic pump. Back end of the tractor still ok, sheet metal is still there. Good for parts. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
