Company Logo Shop Now
Two questions after a fresh rebuild
TNford
06-08-2018 15:22:52
Just started my Ď66 5000 SOS, and have a couple problems.
1) tractor will only run a short time before it dies. 10-15 seconds at first, then itíll stay running a few minutes. Iím guessing this is a fuel delivery issue, so I will be draining tank and looking at screen first. New filters, so the next thing to check would be the lift pump correct?
2) Quite a bit of blow by. Is that normal of a new rebuild?
da.bees
06-08-2018 20:10:18
 Re: Two questions after a fresh rebuild in reply to TNford, 06-08-2018 15:22:52
"Quite a bit of blow by. Is that normal of a new rebuild? "
I've had some"quicky" rebuilds where new pistons and sleeves were not installed that had a little blow by. At most,I expect to use oil at first but "quite a bit of blow by"would worry me.
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: Needing good 70 series fenders. No rust or dents preferred. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
