Company Logo Shop Now
Order Ford 5000 Parts Online
5000 power steering part number
Johnofnewhaven
06-03-2018 11:05:39
third party image
My 1974 5000 diesel has a Plessey power steering pump. The part number is C9NN3K514E. I am not really finding that pump anywhere. Finding many that say it will fit a 5000. Priced from about $250 to $1000. Can anyone tell me what a GOOD replacement pump would be and a part number?
jacob59
06-04-2018 12:04:40
 Re: 5000 power steering part number in reply to Johnofnewhaven, 06-03-2018 11:05:39
I just replaced my pump with a new one. It came off a 4600. Gear pump. Let me know if it will work on your tractor. I have a new seal kit also.
Jack
third party image
Johnofnewhaven
06-04-2018 12:30:07
 Re: 5000 power steering part number in reply to jacob59, 06-04-2018 12:04:40
Hi Jack. It might. What I need is a part that is inside. My email is should be open.
ed1
06-04-2018 03:18:38
I have a 74 5000D, went through the same thing! Pump from NH was 1100.00, 200.00 on eBay and all over the place everywhere else.I have rebuilt it 2 times over 4 years and so far it is working good. Next time I would like to find a good quality pump at a reasonable price. Good luck,ed1
IanC
06-03-2018 11:32:30
3K514 is the base p/n for a power steering pump. I used the online parts catalog to look up the part numbers. An old paper catalog may have yet another number. If you have a 5000 utility the OEM p/n is E6NN3K524EA99M which subs to new style number 87759440 1100 psi and 2.74 gpm. If you have a row crop (5200) then pump is D6NN3K514A which subs up to E6NN3K514LA 1100 psi and 3.5 gpm. I looked at the pump this site offers and it does bot match any of these numbers, nor does it list the specs. The gear and mount are all the same the difference are in the gpm, relief pressure, outlet position and type, and return fitting type. Call tech support for the parts portion of this site and have them give you the specs and see if the fittings match yours.
Johnofnewhaven
06-03-2018 12:14:54
 Re: 5000 power steering part number in reply to IanC, 06-03-2018 11:32:30
Thank you for the info. My 5000 is a 1974 diesel utility. Not a row crop.
Shaun Wallace
06-03-2018 11:19:00
All the numbers found stamped or cast on any product that Ford made are enginning numbers.They denote what era and year and what used on.
Latest Ad: need 3 point arms (with the ball) especially need the [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
