Company Logo Shop Now
Identifying Ford tractor with serial number.
Red Headed Coon Azz
06-03-2018 10:53:59
I would appreciate a little help identifying and dating my new to me Ford tractor. The numbers look like:
641
6465
Although the 6 before the 41 on the first line could be a "b".
Any help is appreciated.
Red Headed Coon Azz
06-03-2018 13:40:06
 Re: Identifying Ford tractor with serial number. in reply to Red Headed Coon Azz, 06-03-2018 10:53:59
Thank you very much. I think I'm starting to understand the decoding of the model and serial numbers.
The first set of numbers, "641", is the model number.
The 6 means it is a four wheel utility type with adjustable front axle and has the 134ci gas engine.
The 4 means it has a four speed transmission.
The 1 means it is the "01" series which was produced from 1957 to 1962.
The second set of numbers, "6564", is the serial number.
1001 was the first serial number in 1957 and 11996 was the first in 1958.My tractors serial number 6564, falls between those two numbers so it was made in the 1957 production year. Correct? Or at least close to it?!?!
Once I am sure of the model and year I can start to address a few issues that came with it. I will be able to order parts with confidence. Again, thanks. RCA.
Larry NCKS
06-03-2018 11:38:12
Check here: John Smith's Old Ford Tractors
Red Headed Coon Azz
06-03-2018 11:29:22
Sorry but after checking my notes I realized that I have it backwards. The second line of numbers are 6564. NOT 6465.
IanC
06-03-2018 11:39:46
 Re: Identifying Ford tractor with serial number. in reply to Red Headed Coon Azz, 06-03-2018 11:29:22
601 series with 4 speed transmission. Per service bulletin supplement number 23 dated July 1992, X01 series started with serial 1001, 1958 production started at serial 11977, so your tractor is a 1957 production.
Andy Wickiser
06-03-2018 13:04:14
 Re: Identifying Ford tractor with serial number. in reply to IanC, 06-03-2018 11:39:46
Keep in mind that the production year can vary from the model year. In this case the model year is 1958 as the 601 series began with model year 1958 although production started in 1957. The model year is the one used when looking for parts. Below is a page from the Ford 4 Cylinder Tractor 1953/64 Parts List. Note that Model 601 tractors have a year range of 1958 - 1962.
third party image
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: Needing good 70 series fenders. No rust or dents preferred. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
