Company Logo Shop Now
Select-0-speed PTO cable parts question
gofast12
05-17-2018 18:14:26
I have a '64 4000 4cylinder with a select-o-speed. The piece that comes through the hood has stripped threads on both ends. If I disconnect the cable will it pull out through that cast piece so I can just replace that cast piece if I can find one?
gofast12
05-25-2018 04:47:02
 Re: Select-0-speed PTO cable parts question in reply to gofast12, 05-17-2018 18:14:26
Thanks.
Larry NCKS
05-17-2018 20:17:42
You must be talking about the PTO cable???? The T handle unpins from that assembly. Other than that, the only piece that should be removable from the body is the conduit. It should only be removable from the cable if the entire assembly is separated completely from the tractor.
DO NOT
. . . and I repeat DO NOT attempt any of this without a thorough knowledge of procedure or you'll have more problems than you know what to do with.
riveroadrat
05-17-2018 19:22:41
Someone just posted on that a day or so back. Click on modern veiw and at the search bar at the top type in SOS cable replacement. When the page resets hit search again. I hear you have to be careful around those when they are running.
Today's Featured Article - Box Plow Blues - by Tom Schwarz. One of the first implements most tractor owners obtain is the box plow. For very little money, this piece of equipment promises to plow and flatten any hill or vale on your ranch road or farm. At least that's what I thought! As simple as a box plow appears, it can be rather challenging to make work correctly. In our sandy soils of Florida, traction is king. You can never have wide enough tires or heavy enough weights to get all the traction you want unless you own a monster tractor. U ... [Read Article]
Latest Ad: Oliver model 101 1-16 rope trip plow on steel. Includes new share/point and great mouldboard. 300 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
