Company Logo Shop Now
Order Ford 600 Parts Online
Ford 9600 tractor
Buzzboy
05-17-2018 11:17:29
I parked my Ford 9600 mid last year. When I tried to use it this year, it cranks and runs... but I can't get it to shift out of park..
Can anyone offer any suggestions on what the problem could be? Thanks. Buzzboy
showcrop
05-18-2018 04:47:13
 Re: Ford 9600 tractor in reply to Buzzboy, 05-17-2018 11:17:29
I just remembered that once or twice I was not able to get mine to release before releasing the chains on the trailer. Tension can keep it bound up, but I still believe that it is far more likely to be external.
showcrop
05-17-2018 16:05:35
I can't think why it would happen, but I can't see it being anything inside. The linkage is on top of the tranny, and if you have someone working the lever you may be able to look in under the deck and see where to put pliers on the bell crank to help it.
Buzzboy
05-18-2018 08:09:51
 Re: Ford 9600 tractor in reply to showcrop, 05-17-2018 16:05:35
Thank you for the information. I'll try your suggestion about the linkage. It is not connected to anything, so it is not under any pressure.
riveroadrat
05-17-2018 14:30:23
I dont really know those trannys but look it up on CNH partstore to see how it works. Those are good tractors by the way. It may have settled in the dirt putting pressure against the pawl. You might give it a little nudge one way or the other and block the tire. It might move right out then. Dont force anything though. It could be in linkage also.
riveroadrat
05-17-2018 19:14:11
 Re: Ford 9600 tractor in reply to riveroadrat, 05-17-2018 14:30:23
I looked at the tranny pics, I couldnt copy them. It looks like your parking is connected to gearing sort of like an automatic transmission parking awl. A little rock and roll and it might dance with you.
Buzzboy
05-18-2018 08:04:58
 Re: Ford 9600 tractor in reply to riveroadrat, 05-17-2018 19:14:11
Thank you for the suggestions.. I'll try them all.
2 9600
05-18-2018 14:44:02
 Re: Ford 9600 tractor in reply to Buzzboy, 05-18-2018 08:04:58
look in the dash make sure you aren't just in between the shifter rails with the lever happens a lot
Latest Ad: John Deere A 1945 styled [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
