steven in Tn
got around to checking pressure today, got the oil temp up and installed a gauge. i had to guess on rpm since tach is broke but should be real close to the recommended 850 rpm and with pto off gauge reads 30psi with it on drops to 25 psi. i also tried it around 16-1700rpm and got 60psi off and droped to 55psi with pto on. what does the manual say i should do now?
btw my neighbor said he has a manual but lives couple hrs away and could be awhile before he comes back down this way. so might need some more scans if you dont mind bern. and thanks again.
