Company Logo Shop Now
Order Ford 661 Parts Online
6610 pto slipping?
steven in tn
05-10-2018 17:39:08
ok so bought a 6610 last fall to use to cut hay and a backup for the baler if ever need it. today we tried to use a 3pt tiller on it for the garden and it took a couple of secs for the pto to engage and when started digging with it would slow down and eventually stop. guessing the pto clutch is bad? or could it be something else? anything that could be out of adjustment or anything? the lever was staying engaged not popping out. its single speed ipto.
how much trouble is it to replace the clutches?
steven in Tn
05-20-2018 04:20:42
 Re: 6610 pto slipping? in reply to steven in tn, 05-10-2018 17:39:08
and a huge thanks to bern. he sent me scans of his manual that i needed to do the job and answered numerous emails. top notch guy.
steven in Tn
05-20-2018 04:19:46
for anyone that runs into the same problem i had, mine turned out to be a missing oring on the pickup tube on the pto valve that comes from the pump. it was completely gone and leaking like a sieve.
sotxbill
05-14-2018 18:31:41
Should be over one hundred lbs...
stripped shaft, bad pump, feed hose came off pto valve?
Grandpa's Fords
05-14-2018 06:50:09
I'm sorry I can't add anything constructive to this but got my first chuckle today.
"btw my neighbor said he has a manual but lives couple hrs away and could be awhile before he comes back down this way." :) :)
I sometimes have to get my laughs at others expense, forgive me :P
I used to work in metro areas and refer to my neighbors that were 2-3 miles away living in the country. But most of my neighbors were closer than yours. 8) 8)
steven in Tn
05-13-2018 17:15:20
got around to checking pressure today, got the oil temp up and installed a gauge. i had to guess on rpm since tach is broke but should be real close to the recommended 850 rpm and with pto off gauge reads 30psi with it on drops to 25 psi. i also tried it around 16-1700rpm and got 60psi off and droped to 55psi with pto on. what does the manual say i should do now?
btw my neighbor said he has a manual but lives couple hrs away and could be awhile before he comes back down this way. so might need some more scans if you dont mind bern. and thanks again.
SuperAV Jr B
05-12-2018 19:52:46
First you need to do a pressure test and if that comes out ok u need to remove the pro clutches. Which I believe you can do by taking the 3pt cover off.
steven in Tn
05-11-2018 07:00:52
ill have to get me a manual first, hoping my buddy has one for his 5610, cheapest decent manual i can find is 275 for a jensales one i doubt the IT manual would be any good.
steven in Tn
05-10-2018 18:44:47
no dual power just standard 4 gears with hi/low
Bern
05-10-2018 20:52:37
 Re: 6610 pto slipping? in reply to steven in Tn, 05-10-2018 18:44:47
I'd still be doing a pressure test before I tore into it. Early models had issues with the spring clip at the PTO valve popping loose.
steven in tn
05-10-2018 17:56:05
fluid is just a hair over full so that shouldnt be the problem
Bern
05-10-2018 18:20:24
 Re: 6610 pto slipping? in reply to steven in tn, 05-10-2018 17:56:05
Don't jump to any conclusions until you start with a pressure test. The problem could be in the dual power, assuming you have it. If so, did you by chance notice any difference with regards to PTO operation between low and high range on the dual power?
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: Shaw due all tractor [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
