Ford 2000 3 cyl. Running box blade - heavy. In position control.
When it really starts to dig, it will force/push the 3 point lever down to the stop. i.e. it will not hold position. I noticed on the top 3-point connection, between the coil spring and the cover there should be a felt spacer and a washer or seal? At least that is what I see on the parts diagram. Mine is missing and there is a 1/2 in gap there. Could that be causing the top link to shove/slam the rod in under a heavy dig (pivots the box blade) and somehow forcing the internal cylinder to push the lever down?
Not sure I am describing this right. I can take some pics.
John
John
