rob.h.smith83
New User
Hi all,
I've spent the better part of the day researching, looking at pictures to try to find this answer and I just can't find it so I'm hoping someone out there can help.
I'll make a long story short.
I have a 4610 diesel. There is no voltage regulator (should be an external, long story)
So for the past two years I've just been starting the tractor, turning the key off, and charging the battery on occasion.
So i decided I wanted to fix it properly and this is where I'm confused.
I purchased a voltage regulator from TSC it's for an old ferguson, but I assume it should work the same way?
this regulator has 4 lugs on it. "Bat" "L" "F" and one underneath that I've figured out is supposed to be "Gen"
I hook the BAT to my ignition switch, F to the field on the alternator, and GEN to the "reg" on my alternator. Not charging. however, I have found that if i run a jumper wire directly from the POS side of the battery, to the "Field" on the alternator, it will charge to about 13.7DCV. Obviously I can't leave it like that because I don't want to overcharge the battery. But that does prove that the alternator works right? It seems like the voltage regulator is not kicking power over to the "F" lug and telling the alternator to start charging.
If anyone out there can help me figure this out I'd really appreciate it. Thanks for your time.
