Fred Werring
Bought an 8700 last year for a baling tractor.
Was losing brake fluid out of the back of the master cyl. Just added fluid (ford mineral
oil) every time before I went out to bale, said "i'll fix it this winter"
Photos show the rust/crud out of master cylinder.
Spending a lot of quality time with a drill mounted brake hone trying to get the MC bores
cleaned up. Can't get the piston springs to return the new piston/seals yet.
I realize some of this has probably gotten into the brake cylinders, going to blow out the
brake lines before I put it back together and hope for the best. Can't seem to break loose
the brake lines at the axles without boogering up the lines. Thinking about blowing back
through the bleeder valve with the lines off at the MC...can anybody tell me why this
would be a bad idea?
Fred
Fred
