Company Logo Shop Now
Order Ford 600 Parts Online
600 ford 3 point
benthereford
02-22-2018 12:15:47
Well my 3 point hitch on my 600 ford will go up but not down.it does not have any equipment hooked to the 3 point and the tractor has been setting for 3 years and just got it running.i changed all fluids and filters but the 3 point still will not go down.does it need equipment attached to it for it to go down?
JMOR
02-22-2018 16:59:51
 Re: 600 ford 3 point in reply to benthereford, 02-22-2018 12:15:47
Quoting Removed, click Modern View to seeDepends on the implement attached. If a plow, for instance, and you want it to automatically adjust depth so as to maintain a constant draft/pulling load on the tractor, then put it in Draft mode (lever down). If something other than ground engaging, and you desire a set height, the lever up for Position Control mode.
benthereford
02-22-2018 16:01:16
i know the lowering and rasing leaver but not sure about the draft lever
benthereford
02-22-2018 15:59:12
please tell me the right position of the draft lever for operating 3 point equipment
JMOR
02-22-2018 15:53:10
Quoting Removed, click Modern View to seeUnloading valve isn't in the dump/lower circuit either, but with engine running, I can see the possibility that if stuck in lift position that it could provide sufficient flow to keep arms up while being too much flow for dump/lower circuit to handle. Still should lower with engine off.
JMOR
02-22-2018 15:15:43
Quoting Removed, click Modern View to seerelief valve is normally the term applied to the over pressure relief & there are two in your tractor, neither of which will have any effect on lowering. If he is speaking of another valve, then that is another chapter.
fordfarmer
02-22-2018 15:48:22
 Re: 600 ford 3 point in reply to JMOR, 02-22-2018 15:15:43
Yes, I used the wrong term. What I should have said was unloading valve.
keith williams
02-22-2018 15:09:45
Ben,
There is no force to push those arms down. In cold weather, I can remember having to sit on or push down on them in order to make the arms go down.
Much can depend on the type of fluid you put in the center hydraulic section.
HTH
Keith
benthereford
02-22-2018 13:19:13
where is the relife valve
JMOR
02-22-2018 13:15:36
Sitting in the up position for 3 years, it should have leaked down by now!? Look thru the hyd filler hole and see if control valve linkage is moving. If not , you move it with a big long screwdriver and if still not lowering, remove the plug on the accessory plate, while prepared for an oil bath. If still won't lower, then it is a mechanical bind, possibly 3 years of rust.
fordfarmer
02-22-2018 13:14:25
No, just the weight of the arms should make it go down. You may have a stuck relief valve, after sitting that long.
Latest Ad: John Deere A 1945 styled [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
