Company Logo Shop Now
Order Ford 3000 Parts Online
3pt. stabilizer Ford 3000
johnofnewhaven
01-22-2018 11:23:40
Hello.
I hope the link posted.
Will this stabilize keep my 3pt from swinging from side to side or is it for something else? Does it attach to where the top link attaches to the tractor and then to the end of the lift arms. I do have the stabilizer brackets that bolt to the axle but they need repaired. What do I need? Tired of my 3pt hitch swinging so much! Thank you in advance for your help!
steve19438
01-24-2018 13:14:53
 Re: 3pt. stabilizer Ford 3000 in reply to johnofnewhaven, 01-22-2018 11:23:40
third party image
Ferguson TO-35 with attached stabilizer bars.
Texasmark1
01-24-2018 05:20:16
Repair parts are available at TSC as are the stabilizer bars. That's what I use on my 1000 series tractors. My lift arms have several OEM holes for different types of mount restraining parts.
ptfarmer
01-23-2018 18:27:26
Our 6640 New Holland came with them from the factory.
Hobo,NC
01-23-2018 17:30:18
THOSE ARE NICE... My new tractor has them I luv'em...
ptfarmer
01-23-2018 13:24:21
It already has a hole for the level arm, it won't hurt. You can also buy new, or used lift arms with multiple holes in them.
ptfarmer
01-23-2018 12:32:53
You have either have the lift arms with extra holes, or drill the holes near to where leveling rods attach to.
Something like this.
third party image
Johnofnewhaven
01-23-2018 12:56:05
 Re: 3pt. stabilizer Ford 3000 in reply to ptfarmer, 01-23-2018 12:32:53
Thank you for the picture ptfarmer. I didn't feel good about drilling a hole in the lift arm. Sure seems like that would make a huge weak point!
CTPhil
01-23-2018 11:20:11
It just slides on the pin on the implement after you'd slid the end of the draft link on. There's room for both on the pin.
johnofnewhaven
01-23-2018 11:33:01
 Re: 3pt. stabilizer Ford 3000 in reply to CTPhil, 01-23-2018 11:20:11
I was talking about the stabilizer arms ptfarmer showed a photo of. How do the hook up?
BobReeves
01-23-2018 10:02:15
Probably because you have never had an aftermarket bar. The single Ford bar on my 3000 has worked well for 10 years through everything I have thrown at it. When I bought my 3600 it didn't have anything so I bought an aftermarket kit with two bars.
Had an issue with trying to put both bars on my Flail mower so went with one. First time out came back and noticed the bar was bent. Next spring I'll have to figure out why the holes in the after market bars are too far out to allow both bars to be installed. Pprobably some welding and redrilling in my future.
CTPhil
01-23-2018 05:59:09
Sort of an aside, but I only ever use one stabilizer bar. Been doing it for 30 years, never had an issue.
wellmax99
01-23-2018 05:35:18
Just for the sake of term identification,
I believe the bars you mentioned that go from the ends of the cross bar hitch up to the top hitch pin are called (stay bars)
My TO35 did not have a underbelly hitch installed at the factory, it came with a cross bar hitch, you used the stay bars to keep the hitch bar from moving side to side and up/down,
After we installed the underbelly hitch, it is much more user friendly,
The under axle stabilizer bars are needed for cultivation or and other job you do not want your implement moving back and forth,
Mike(NEOhio)
01-23-2018 05:29:17
I put a set on my 2000. Made a world of difference raking hay on side slopes. Had only one bracket so had to make a second. Be sure the stabilizer pins are in line with the lower link pins of the 3-point. And don't put them on upside down.
ptfarmer
01-22-2018 22:09:44
These are really nice if you can afford them, you can adjust them side to side if you need to offset your 3 point, our 6640 Ford/New Holland has these.
third party image
johnofnewhaven
01-23-2018 10:09:14
 Re: 3pt. stabilizer Ford 3000 in reply to ptfarmer, 01-22-2018 22:09:44
Hi ptfarmer.
I have looked at those bars. My question is one end hooks to the stabilizer bracket on the axle and the other end hooks to the lift arm but where and how? I dont see anywhere to hook to the lift arm. Thany you!
Royse
01-22-2018 20:51:10
Make sure your pin on the axle bracket is lined up pretty close to
the pin for your lift arm or the geometry will be off and they may bind.
BigDanT
01-22-2018 13:10:09
As Sean says also you'll need two bars one for the left side and one for the right side.
johnofnewhaven
01-22-2018 13:14:07
 Re: 3pt. stabilizer Ford 3000 in reply to BigDanT, 01-22-2018 13:10:09
Thank you Sean and Big Dan. I will fix my axle stabilizer brackets and get the stabilizer bars.
Sean in PA
01-22-2018 13:06:48
Yes, it is designed to keep the 3 point arms from swinging side-to-side, but it does not attach at the top link rocker. It attaches to a bracket under the axle and to the lower lift arm. Sounds like you would need to either repair or replace the bracket under your axle before you could use the stabilizer bar.
Latest Ad: John Deere A 1945 styled [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
