Company Logo Shop Now
Order Ford 3400 Parts Online
Auxiliary hydraulics for 3400
85burbanator
12-31-2017 18:57:48
I know they have the kits that mount under the seat to add smaller hydraulics ran off the tractor pump. My book is buried but what psi do those run at? My loader fell off is blocks and sank in the ground during a wet month while the tractor was in the garage getting work done. It's now frozen in the ground and buried in snow. My jd 750 won't lift it with a boom on the 3pt and my buddies skid steer is tied up with snow removal until the season ends.
I'm thinking of fabbing up a truck plow to the front but complete ones are expensive this time of year. I got a line on an older blade with trip springs and lower carrI age but no pump/controlls. How hard would it be to plumb some lines for mark and ad a cylinder to lift/lower and tie in the angle culimders? May just add a winch and drill some holes to manually angle the blade, that's the cheapest and easiest route
85burbanator
01-01-2018 11:04:04
 Re: Auxiliary hydraulics for 3400 in reply to 85burbanator, 12-31-2017 18:57:48
Thank you for the response. I decided to pass and hold out for a complete unit. Should be plenty getting unloaded after the season ends for fair prices.
Sean in PA
01-01-2018 07:24:37
The pump itself should have made close to 3000 psi when new. The relief valve in the 3 point circuit should be set to around 2000 to 2200 psi.
85burbanator
12-31-2017 18:59:47
Edit: I meant to say, plumb some lines to the front and add a lift cylinder. Dang phone changes the right words and keeps the wrong ones
Today's Featured Article - It's Alright Where It Is! - by Anthony West. I have a tale of a different kind to tell. Whilst rooting in the hedge bottoms this week I had cause to visit Chapel lane Farm, the home of an eccentric gentleman by the name of Austin Kendall. I had heard rumours that an old Case Model C was languishing away in the back of one of the outbuildings there. So off I went in search of what would turn out to be a very rare and unusual tractor. Mr Kendall is an excitable chap to say the least. He is amongst the last of a dying breed of farmer who ... [Read Article]
Latest Ad: Fiat 800E/ AgriPower 8000 Tractor for parts. Engine burned, but didnt get the injection pump or hydraulic pump. Back end of the tractor still ok, sheet metal is still there. Good for parts. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
