Company Logo Shop Now
Transmission pattern
Papa78 Jack
11-30-2017 05:10:34
I think I got a 6/4 manual reversing transmission in my 1965 ford 3000 diesel tractor, When I shift it to low range the first gear is in the middle , second to the left, third to the right, when you shift into reverse, you have two, than when you shift to high range you have the 5-4-6 and two reverses. My book says that the TPC# that the number C1012K ( which is the # on my 3000 is a 6/4 manual reversing. Anyone every had one of these, it shifts good. Any info would be helpful. Thanks
Destroked 450
11-30-2017 17:47:10
 Re: Transmission pattern in reply to Papa78 Jack, 11-30-2017 05:10:34
Thanks for the picture , and thanks for telling me about not using the high reverse, don't know why they put it in it . thanks again.[/quote:1b607d7439]
Just to clarify, Low range R1 is like low reverse in a 8 spd (slow),
R2 is a good reverse gear, (I use 3rd and R2 a lot). High range R3 is similar the high reverse on a 8 spd and on good ground I'll use 4th and R3, I stuck mine in R4 once, chart says it will do 14 mph backwards in R4, to fast in reverse for me.
Papa78 Jack
11-30-2017 16:43:51
Destroked 450
11-30-2017 10:18:57
I have that trans on my 4500 industrial, it's rare to see one on a ag model.
The extra reverse gives you a good reverse speed the the 8x2 doesn't have, it also gives you a high reverse speed you shouldn't use.
JoeM(GA)
11-30-2017 07:06:26
C1012K
you are correct
C10=(310) 3000 All purpose 1965-1975
1 = Diesel
2 = Trans 540 rpm
K = 6x4 manual reversing
Ultradog MN
11-30-2017 05:18:58
third party image
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
Latest Ad: Farmall A. A complete restoration of a 1939 Farmall A. Parade ready. Whole motor has been went through. New tires. Everything factory except the stack. Crank start only. OBO [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
