Order Ford 4000 Parts Online
Ford 4000 Serial Number
Gary Martin
04-17-1999 05:24:00
I've bought a used Ford tractor serial number B843469. This number doesn't seem to correspond to any of the serial number lists I find on the internet. Best I can tell the model number is 4014C, but the 1st digit is mostly missing. Can anyone help?
Bern
04-20-1999 17:40:56
 Re: Ford 4000 Serial Number in reply to Gary Martin, 04-17-1999 05:24:00
The reason you can't find much info on this tractor is because your tractor was built in Basildon, England (this is why you have a "B" prefix serial number). From the model number you have I can tell you that it is a "utility tractor", it is diesel, has 540 independant PTO, and an 8 speed transmission. Since the PTO is independant, it would have to be either a 4000 (3 cyl engine), or a 5000 (4 cyl engine). The one character that you can't read will either be a 4 or a D for a 4000, and a 5 or an E for a 5000 (numbers for pre 68's, letters for post 68's).
