morning: Still chasing this 3000 3pt lift operation, I attached a photo or two of the assembly, and i see wear on the pin that the main arm cam runs against.
When the lift handle is raised, the cams move and the spool valve goes forward into the body, but only works if the position/draft lever is pushed ahead to force the spool valve slightly more ahead.
The p/d lever just flops back and forth about 2.5/3 inches, and doesn't go below the aux valve hose connections[ someone had a photo of the p/d handle down past the aux valve when in draft position?]
Also there is about 1/4 inch gap between the main control arm and the p/d operated assembly, that pushes against it, and the the d/p connecting linkages all have slack movement no matter where the position control lever is placed.
The full raise position does push the spool valve forward, and works if the p/d lever has been forward and back, and the control lever to lift was in the full down position to start with.
Hope that didn't confuse everyone? lol
Has anyone got a pdf of the adjustment operation, hope the photos explain what I found.
Tks
