I have a 1983 Ford 5610 with Cab and MWFD and loader. Recently I had a shop put on a new power steering pump. At the time I was told the pump that was on it was the wrong one as it had too high of pressures which is what caused the side of the steering column to break or burst. So we went with the smaller pump but not the issue is it’s hard to turn and physically won’t turn front wheels at a stand still. Can anyone confirm the correct part number for me?
Re: Correct power steering pump Ford 5610? in reply to FordManiac, 11-14-2017 09:38:29
Should be the first choice listed at the link below. That said, even the correct pump won't be up to the task. That steering system was never designed for big front tires and loaders, which is why Ford changed those models over to hydrostat steering in 1985.
Today's Featured Article - Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
Latest Ad:
need 3 point arms (with the ball) especially need the
[More Ads]
