Company Logo Shop Now
TW35 axle housing gasket
RLP in Co.
10-30-2017 09:47:56
Is the steel gasket reusable with some good sealant?
Do they use sealant with a new steel gasket?
RLP in Co.
10-30-2017 20:56:46
 Re: TW35 axle housing gasket in reply to RLP in Co., 10-30-2017 09:47:56
Thanks Bern for the reply. That is good news! I guess that there is clearance enough in the shaft and gears to eliminate the metal gasket.I think I'll use that new permatex ultra black. I used that once before and that is some good stuff. I'll have to make some pilot bolts like your article suggested.
Luckily I didn't have to take the axle out of the housing. I just swapped housings with the junkyard. I even got a little bit better sun gear than mine was. Mine had a little hauling on one tooth.
Now if the warm weather would come back!
Bern
10-30-2017 10:41:18
third party image
I would chuck the gasket and use some anaerobic sealant instead. Above are instructions for the Genesis tractors, which replaced the TW/8030 series tractors.
Did you get your shimming process all figured out?
Latest Ad: Looking for two coulters and mounting brackets for a JI Case centennial plow [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
