Ford Tractors Discussion Forum |
6610s injection pump timing
Author |
[Modern View] |
Harry in Ky
10-14-2017 15:13:20
Anyone out there have a book listing the static pump timing for a 6610s? This has a Lucas DPS pump with timing lock bolt. Am down to the final stages of removal, all that's left is popping the gear off the shaft and removing the three pump mounting bolts. I'm quite sure the engine is properly positioned since the bolt heads are in register with access holes in the gear and flywheel timing marks are visible in the window. Just not sure what degree mark I should be looking for when the pump goes back on.
thepumpguysc
10-15-2017 03:05:34
Re: 6610s injection pump timing in reply to Harry in Ky, 10-14-2017 15:13:20
If I'm not mistaken, there should be an extra hole in the pump drive gear at 6:00. You PIN the gear, lock the pump & pull the gear off..
Harry in Ky
10-15-2017 06:54:12
Re: 6610s injection pump timing in reply to thepumpguysc, 10-15-2017 03:05:34
I don't recall an extra hole in the gear as described, but then I wasn't looking for one. Got to a stopping point yesterday in need of the proper puller bolts to fit the threaded holes in the gear. I think I now have what I need so will take another stab at it today.
Harry in Ky
10-15-2017 13:04:40
Re: 6610s injection pump timing in reply to Harry in Ky, 10-15-2017 06:54:12
Okay, the pump is off. There is no timing hole in the gear. I backed the engine to the 30 degree mark which pretty much centered the mounting bolt heads with the holes through the gear. When the pump goes back on I can roll the engine forward to the proper mark(whatever that is) then tighten the gear onto the shaft.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
990 7 foot mower conditioner john deere hay rake pto driven john deere head carrier
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
