Company Logo Shop Now
Order Ford 861 Parts Online
Ford 861 Starter Button Issue
LJS30
10-14-2017 15:05:48
Okay guys I am back again. My mechanic replaced my starter button and wired up my 6V solenoid up correctly. At first things were fine and it started up properly. However after installing a new air cleaner tube something weird occurred. When I go to start the tractor it cranks over WHEN I TURN THE KEY!!!! It's almost like the starter button has either malfunctioned or been bypassed somehow completely!! What in heck is going on!?!? Can I continue to use the tractor in this state?
Larry NCKS
10-15-2017 12:13:27
 Re: Ford 861 Starter Button Issue in reply to LJS30, 10-14-2017 15:05:48
It could. But more likely you pinched the wire from it to the solenoid and it took it a bit to wear through and short out.
LJS30
10-15-2017 09:55:35
Could the starter button have been defective? Because after my tube install it work fine for two presses then the rest was history.
LJS30
10-14-2017 15:30:37
Yes it was working fine until I had to disconnect the cable to the starter to install my new air cleaner tube.
old
10-14-2017 21:35:43
 Re: Ford 861 Starter Button Issue in reply to LJS30, 10-14-2017 15:30:37
Sounds like you unhooked a wire then put it back on in the wrong place or you some how have shorted out the wire going to the starter button. Either way DO not even try to run it as is or you will be replacing the starter and maybe the battery and even the wiring
LJS30
10-14-2017 15:26:24
I'll check that wire and see what's going on.
Royse
10-14-2017 15:15:38
Your started button provides ground to the solenoid to start it.
Sounds like you have somehow pinched or grounded that wire.
No, you can't keep running it that way without causing damage.
WayneIA
10-14-2017 15:15:23
Unhook the battery. The solenoid is right behind the air cleaner tube. Your mechanic needs to recheck what he did. Obviously, he didn't get things in order.
Today's Featured Article - Recollections of a John Deere GP - by Charlie Cook. I grew up on my dad's 280 acre general farm in Western Michigan. Dad's only tractor when I was very young was the old GP. My first recollection of this tractor was when dad allowed my brother and myself to ride on the tractor with him driving. One of us would sit on the left fender (away from the clutch) and other would sit on the gas tank and hold onto the crankcase breather pipe. ... [Read Article]
Latest Ad: Wanted front suit case weights and rear wheel weights for a 1456 international. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
