Power steering rebuild problem
makoman
62 4000 power steering pump started gushing. Bought rebuild kit. Can't get the big valve nut off. Would rather not torch it, any thoughts?
Where can you get a new rotor, rollers and cage for this pump? A big vice and a big wrench to get the valve out.
That pump is used on several applications. Eaton made pump, resivour was made for whoever used pump. Parts may still be avaible thru New Holland. Case used same pump on 8 speed 930s.
