1960 ford 801 injection pump
How to bleed the air out of a Roosa master pump. I forgot is there 1 or 2 points which need to be opend for air on my 1960 ford 801. I ran it out of fuel and can't get it primed there is no lift pump and filter is full. Would be much appreciated thank you.
There are four points once you get the filter full: the four injectors. It takes a couple weeks of cranking to get all the air out. Your best bet, if you are in a hurry, is to tow it.
Thank you Showcrop. I spent way too long it today. Will hit the floor with it in fourth tomorrow am. Thanks again ya all stay safe!
