Ford Tractors Discussion Forum |
Compression on 5000 gas
Author |
[Modern View] |
TN 2N
09-13-2017 18:57:37
I am looking at an older Ford 5000 ( pre '67) gas burner. Want to do a compression test. What numbers would be good/acceptable, dry and wet?
Ultradog MN
09-14-2017 02:55:45
Re: Compression on 5000 gas in reply to TN 2N, 09-13-2017 18:57:37
The big Ford manual says 115-150 with max 25 psi variation between cylinders. Says all plugs out, throttle open, 200 rpm cranking speed. These would be dry numbers. The wet/dry test would only be used to determine if a low number was caused by rings or valves and not for determining overall condition of top end. Good luck on getting it.
TN 2N
09-14-2017 06:44:11
Re: Compression on 5000 gas in reply to Ultradog MN, 09-14-2017 02:55:45
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit
... [Read Article]
Latest Ad:
Needing good 70 series fenders. No rust or dents preferred.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
