my '78 3600 has a remote valve located under the seat. it has 2 levers (2 spool?) and the hose connections on the back of the tractor are 2 pair (double acting). i have one pair connected to a dunham-lehr loader.
the remote has 2 levers which have detents in 3 positions, fwd, center and aft. fwd operated the loader, center allowed the 3pt arms to operate, and back ???. i have always moved both levers to the same position when operating.
is the aft lever position for the second pair of (unused) remotes?
the manual says the right spool valve of a two spool remote has the float valve. there is also a float valve adjustment on the valve block. can someone please explain how to use the float feature on this remote setup?
