4000 ford 5 speed tighten up
riveroadrat
Has anyone out there ever pulled the front bearing caps on a 5 speed to tighten up that end while the input shaft is out? Can you replace the top and bottom bearings? I know I can replace the bottom shaft bushing. Also can you take up some slack in the upper and lower shafts through the hydraulic top cover hole?
