Company Logo Shop Now
Order Ford 860 Parts Online
860 PTO problem
tractorguy2
07-03-2017 14:52:06
Installed a new double clutch in the 860 two years a go. Was working fine till this spring. The PTO clutch will not release so I can engage the PTO without grinding. Have adjusted it with the instructions in the IT manual. Did not help.
lonestarjeff
07-08-2017 18:28:13
 Re: 860 PTO problem in reply to tractorguy2, 07-03-2017 14:52:06
I have a similar problem going on....not a new clutch, but this last week the pedal suddenly will not disengage the pto clutch. The only other previous thing I'd noticed was the engine loading up a bit when I put the clutch pedal to the floor.
Did you try SouNdguy's suggestion? Just wondering if you cleared yours up.
Jeff
soundguy
07-05-2017 11:24:14
block the clutch down for a few days and see if it pops loose.
If not, hookup a pto implement like a mower and keep the clutch blocked and bump the engine over.. might pop it loose.
Larry NCKS
07-03-2017 17:10:03
Maybe stuck over winter from non-use???
Latest Ad: John Deere A 1945 styled [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
