Company Logo Shop Now
22A Generator Regulator
Texasmark1
07-01-2017 05:47:57
Did Ford and aftermarket have one design or are there numerous? Tractor is a '65 3000D.
Thanks,
Mark
BobReeves
07-01-2017 16:33:11
 Re: 22A Generator Regulator in reply to Texasmark1, 07-01-2017 05:47:57
How can one tell the difference?
Bern
07-01-2017 19:36:44
 Re: 22A Generator Regulator in reply to BobReeves, 07-01-2017 16:33:11
According to the service manual, the 22-amp models had a fan, and the 11-amp versions did not.
You can see a few differences by looking in the parts manual.
Bern
07-01-2017 06:08:30
Original ones said "Lucas" on the cover - replacement ones did not.
RickB
07-01-2017 13:41:08
 Re: 22A Generator Regulator in reply to Bern, 07-01-2017 06:08:30
Yes. But there is one design for all Ford tractor applications so far as I know.
Texasmark1
07-02-2017 05:56:28
 Re: 22A Generator Regulator in reply to RickB, 07-01-2017 13:41:08
The manuals I have do discuss an 11A and it's not part of the diesel tractor's OEM equipment. My OEM regulator specifically stated LUCAS on the cover and 22A on the metal back side. My after market replacement has a sticker on it with 12v/22A on the back side. Not made by Lucas.
Bern
07-01-2017 14:33:04
The original '65-up tractors had both 11- and 22-amp generators available, each with their own unique regulator. I've never seen a true 11-amp generator that I could put my hands on, either because most tractors came out with the 22 amp, or more likely, when the 11-amp models failed, they were replaced with the 22-amp versions. 11 amps is good for keeping the battery charged and not much else.
RickB
07-01-2017 16:52:09
 Re: 22A Generator Regulator in reply to Bern, 07-01-2017 14:33:04
We're talking Fords so I said "so far as I know" :.) I've not seen an 11 amp generator.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
Latest Ad: Farmall A. A complete restoration of a 1939 Farmall A. Parade ready. Whole motor has been went through. New tires. Everything factory except the stack. Crank start only. OBO [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
