Most likely a worn main hydraulic pump. The dealer should have a tool that he can use to performance test the pump directly, ahead of the remotes. If not, suggest removing the pump and disassembling it for inspection.
The problem could also be a bad priority valve pack, and/or stuck combining valve inside said pack. This is why I would test the main pump before I did anything else.
