Company Logo Shop Now
Hydraulic inlet tube elbow?
BobReeves
06-11-2017 12:21:01
Anyone know how the inlet tube elbow in the rear end that holds the tube from the pump is held into the case. Parts only shows an O-ring. I thought it might just be a slip fit like the tube but it doesn't seem to want to pop out of the rear end.
Hoping it isn't held in with a clip or something on the inside that can only be removed through the top cover.
Ultradog MN
06-11-2017 12:54:33
 Re: Hydraulic inlet tube elbow? in reply to BobReeves, 06-11-2017 12:21:01
third party image
It screws in.
BobReeves
06-13-2017 07:42:30
 Re: Hydraulic inlet tube elbow? in reply to Ultradog MN, 06-11-2017 12:54:33
Exactly what I needed to know, thanks.
Might as well be held in by something under the cover, you can't unscrew it without first removing the brake and clutch cross shafts. That O-Ring can wait until I have to rebuild the cover.
BobReeves
06-11-2017 12:23:06
Probably should have said it's a 3600...
Latest Ad: Looking for two coulters and mounting brackets for a JI Case centennial plow [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
