Ford 5000 rear wheel adjustment
dannyidp
What Is the easiest way to adjust the wheels on the 5000 Ford. I am also wondering how many locks there should be on the Wheel looks like I have two
Had to look at you restoration pics to see which style wheel you had, early 65-68 style with the adjusting nuts.
There are two stops that bolt to one of the rails, there are large clamping nuts and holders bolted on the wheels center that adjust and puts a clamping force on each rail.
You'll need to loosen each nut the same amount, move one of the stops to where you want the wheel positioned, spin the wheel in or out to the position you want and move the other stop next to the wheel. The stops prevent the wheel from spinning in or out should the clamping nuts get loose.
Thighen the clamping nuts equally and turn the wheel to make sure it doesn't wobble and isn't out of round. Sometimes you have to loosen the nuts on the high side and tighten the ones on the low side to get the wheel centered.
